  • 5 Replies
  • 4178 Views
Moe52
Arrrrg!! Contact Us says if I am in warranty, to start a case at this page:
https://www.arlo.com/ContactUs/login.aspx?ReturnUrl=/ContactUs/SupportRequest.aspx
but when I enter email and password, nothing happens. I reset the password, still fails. Stuck.
JessicaP
Hey Moe52,
Try using a different browser or run on incognito mode and use this link to see if that helps: Arlo Support Team
5 REPLIES 5
JessicaP
Hey Moe52,
Moe52
Using another browser worked -- but could you turn in a bug report? Your login really should work for all popular systems, yes?
I'm on Safari on Mac (OS X 10.14.6).
JessicaP
Let us know which browser you had problems with and we'll share your feedback to the relevant team.
Moe52
I already gave that:
It works ok with Chrome.
JessicaP
Thanks for clarifying on that. I'll share this over to the relevant team.
