What other cameras does the base station support? The Arlo does not see far enough at night for one of my applications so I need to use a different camera but like the Arlo design.
Message 1 of 4
1,545
None. If you want longer night vision distance, Google IR spotlights - Amazon has a ton. Make sure they're 850nm lights.
Message 2 of 4
1,535
what about the 940 nm bulbs? they will not work with the Arlo outside camera?
Message 3 of 4
1,524
Dunno that anyone's tried. If there's sufficient spread in both the capability of the camera sensor and filter as well as from the bulb, maybe. I tend to think it wouldn't be useful.
Message 4 of 4
1,520
