More than 5 camera???
  • 6 Replies
  • 5205 Views
  • 4 Likes
Chung
Hello,  I'm looking at my house and I believe I will need around 6-7 Arlo cameras.  It looks like the router base only controls up to 5 cameras so does that mean I would need to purchase another base to support the extra cameras?
6 REPLIES 6
One base station will easily connect to those cameras. However, you'll need to upgrade the service from Basic to something else sinyBasic only works for up to and including 5 cameras.
Chung
Ok, so if i want to keep the basic plan, i'd have to get another router to accommodate the 1-2 extra cameras?
RegDawg
I believe the system is account connected. So even by getting another base station you'll still need to upgrade the plan. I'm wanting to get another 1-2 camera's as well but debating the monthly cost.
you can buy 2 systems with 3 cams each and sign up to 2 accounts ( diff emails )
That will keep you in the basic/free plan. You need 2 bases connected to the router via ethernet ( so you need two free ports )
Or go 1 level up to Premier for 10 cameras with one base ( it will handle all but only live stream 4 cameras at same time )
Chung
Cool, might go that route.  I'll have plenty of ports since I am remodeling the house and putting a lot of RJ45 connectors around the house.  Thanks for all the suggestions.
For clarity, you don't need another router, just another base station (and subscription to support it).
  • 6 Replies
  • 5206 Views
  • 4 Likes
