  • 5 Replies
  • 2201 Views
Andyw0530
Are the Arlo cameras backward compatible for use on the same base as a mix of Arlo cameras?  I'm wanting to add more cameras including a1080 Q camera, but didn't know if I need to also upgrade the base.  Can older Arlo base can handle any new Arlo camera addition?  Thanks!
5 REPLIES 5
The Arlo camera and the Q will work together but maybe not like you think.
The Arlo cams hook into the Arlo base ONLY, the Q cam hooks into you home wifi system.
They will all appear together in the PC/apps but you have to arm them separately..  Arm the Arlo cam and them arm the Q's
So in effect, the base makes no diff to the Q cams
roy9183
Hi ,
Good to know that both Arlo Q and Arlo Wireless work in the same account.
However can someone clarify if , I have 2 different cities i.e. one location having 2 wireless cameras and other location having 2 Arlo Q . Can i still use one sigle free account to watch all four cameras.?
Thanks.
Yup.
Andyw0530
roy9183
Just tried the same. Just followed the steps and setup the ARLO Q. It works perfectly.
  • 5 Replies
  • 2202 Views
