How many cameras will VMS3430 support.
  • 2 Replies
  • 13846 Views
timpennell
Is there a limit on the number of cameras supported by the packaged systems?
 I plan to add additional cameras over time.
Thanks,
AnthonyArmato
Luminary
Luminary
Just remember as to the # of cameras (based on plan ), you can still ONLY live stream/record from 4 at the same time per base.
(base limits to 4 at a time so thru-put isn't degraded) If you need more than 4 live at the same time, you need another base in addition.
  • 2 Replies
  • 13847 Views
