How many cameras will VMS3430 support.
Is there a limit on the number of cameras supported by the packaged systems?
I plan to add additional cameras over time.
Thanks,
Message 1 of 3
13,868
Searching is your friend...
Message 2 of 3
13,847
timpennell wrote:Is there a limit on the number of cameras supported by the packaged systems?
Just remember as to the # of cameras (based on plan ), you can still ONLY live stream/record from 4 at the same time per base.
(base limits to 4 at a time so thru-put isn't degraded) If you need more than 4 live at the same time, you need another base in addition.
Message 3 of 3
13,597
