white band blocking top third of camera view...can't remove it...why on Earth???
I want one third of my money back.
i just checked full screen on my computer using IE and I don;t see any such bar
I see what you mean, But I find it neither large nor intrusive.
yeah guess it depends.
maybe on suggestions (forgot exactly what its called) you can put that in.
be ironic if they added bar because people requested it
The settings bar within the camera widget does not block any of the viewable area within the cameras field of view. This bar is simply added above the cameras field of view, none of the scene is lost.
Maybe you should explain what phone/OS you have. My Nexus 6 phone and Nexus 10 tablet have no issues.
Phone is note 4
mart-ian,
While I do not have a note 4 specifically to test this, all Android mobile phones should display this the same way. Can you post a screenshot of what you are describing?
