which model of arlo I have?
  • 5 Replies
  • 8463 Views
jfc650
Can somebody help me to find out which model I have with the following information? I  am trying to connect the device to my general wifi router (mesh). I am required to select a Arlo model to setup the connection.
Device Info:
Firmware:1.5.295
Hardware: H11
Serial Number: 4WA16B7U78E0B
Best answers
  • dcfox1
    @jfc650 wrote:
    Thanks.
    It would be great if Arlo can post a document/web-page indicating which  model can connect to which base/route/hub. Really get confused in terms of which product can connect to where.
    They do. Arlo SmartHub and Base Station Compatibility
  • Dannybear
    The base station model number should be on the device as a sticker, look under it for starters.
    For the cameras look inside the battery compartment for same.
5 REPLIES 5
Dannybear
jfc650
Thanks for the answer. I found  the model in the battery area. VMC3030, Arlo Wire-Free Camera.
Can I connect it with general wifi router or it has to connect with Netgear SmartHub?
Thanks,
Only a hub.  Note Arlo hasn't been part of Netgear for several years.
jfc650
Thanks.
dcfox1
@jfc650 wrote:
Thanks.
