Hub Firmware 1.17.0.0_1180_6ba79e5
Hub Hardware VMB3010r2
Camera Firmware 1.5.295
Camera Hardware H7
All four cameras just went offline for no reason.
Rebooted the hub and it is connected to the internet and I can see it in my router table.
Tried to sync a camera-no response
Tried replacing batteries-blue light on camera blinked once
What is my next step? I've never had a problem with these until now. They usually work flawlessly.
Thanks for the info!
I replaced ALL the batteries in all 5 cameras and re-synced them one at a time to the hub.
I still don't know what happened to cause this. Glitch in the matrix?
Anyway, I'm back up and running. Sadly, I missed recording a failed porch pirate attempt.
As soon as they opened the box and discovered nothing but dog food, they lost intrest!
Thanks for all your help!
Have you tried placing a camera near the base station and do a manual resync?
What are the LEDs on the base showing?
Sometimes it's just best to reset the system and start fresh, which can save a lot of time and anguish. Remove all devices from Settings, My Devices. Hold the reset button until the LEDs flash amber. Let the base reboot to green power and Internet LEDs and start as if new. Note all settings, modes, rules, schedule, etc. before doing this to speed the rebuild.
Appreciate the suggestion. All I have or original cameras.
I plan on buying a snazzy new system when I win the lottery. (darn, that new stuff is expensive)
After replacing batteries and doing a re-sync with the hub, I'm back up and running.
Thanks for the reply!
