Can somebody help me to find out which model I have with the following information? I am trying to connect the device to my general wifi router (mesh). I am required to select a Arlo model to setup the connection.
Device Info:
Firmware:1.5.295
Hardware: H11
Serial Number: 4WA16B7U78E0B
Best answers
@jfc650 wrote:Thanks.
It would be great if Arlo can post a document/web-page indicating which model can connect to which base/route/hub. Really get confused in terms of which product can connect to where.
The base station model number should be on the device as a sticker, look under it for starters.
For the cameras look inside the battery compartment for same.
Thanks for the answer. I found the model in the battery area. VMC3030, Arlo Wire-Free Camera.
Can I connect it with general wifi router or it has to connect with Netgear SmartHub?
Thanks,
@jfc650 wrote:Can I connect it with general wifi router or it has to connect with Netgear SmartHub?
Only a hub. Note Arlo hasn't been part of Netgear for several years.
Thanks.
