which is more sesitive 0% or 100%?????
100
isit normal for the motion light on the camera to never flash no matter what comotion you do in front of it?
The motion ( led ) light will flash if in camera position mode (under settings)...this is a test mode only.
Other than that the LED will slowly flash amber if the batteries are low
