Is there a way to clear all the times I have set up under the schedule tab? Problem is I have most of my times set for after midnight to turn on my cameras and when I change them to earlier it says start times should be earlier then stop times. I try and change the stop time and it says the same? I just want to be able to clear all the pre arranged times I have set.
Message 1 of 3
1,816
Set the stop time first. Also, you can't span days so use something like 8PM to 11:59PM an then 12AM to 6AM.
Thanks! I will do that for now on.
Message 3 of 3
1,803
