vms3430 - 100nas : What kind of camera is it? Pro, Pro 2, Pro 3, Pro 4, Essential, Ultra? I am trying to figure out which one to choose to configure and sync the camera.
This can get complicated, as Arlo has a lot of different skus. Anything that starts with VMS is a system sku - all the cameras start with VMC.
None of the above. You purchased a really old system, with the original Arlo WireFree HD cameras (VMC3030). Just to confirm this - your cameras should take 4 CR123 batteries. All the other cameras on your list use custom lithium batteries.
To add the camera, you need to select Add Device -> Cameras -> Other -> Arlo
You might need to scroll down a bit to see "Other".
