How on earth do I start a trouble ticket? Thanks
go here; http://www.arlo.com/en-us/support/contact.aspx
contact netgear
contact netgear
For general consumption, click on the Support link at the top right of these pages. Then, under Helpful Links on the right side is Contact Support. Various option there...
Use the app and select Library. Select a day with a green dot and you should see any videos recorded. Click on a video to be able to watch it.
Re problem I had cleared after downloading/installing NETGEAR GENIE file and - no more annoying notification on the Windows screen.
Thnaks for your help.
Regards,
A. Nagai,
Hoozat wrote:
Just loops and loops never get to a place to actually contact support
Huh? Support link at the top of these pages and Contact Support on that page.
