sync button ,usb led flashes
I am computer gene less.
When I push the sync button on the base the USB LED flashes . How do I fix this so I can sync the cameras
When you push the 'sync' button, the camera led should flash...
Have you tried just rebooting the base by turning off (power button) and then turning back on .. reboot takes about a min or two till all leds are back on
TomMac , thank you for the input I did reboot dont know w.I beleive I held the sync button down longer than neccessary.Ithink it was my mistake.Thanks again
