motion detection and sound detection issues with firmware 1.090.0.0_9945. Everything was working fine till this firmware upgrade was pushed out
Bob
AS of 2:15 EST i started to get motion detection notificateins and the cameras are recording again.
If you'all did something thanks.
Bob
Mine was only updated last night so don't have much experience with it yet. Have you checked your rules and settings to ensure nothing changed in them?
Thanks and yes I have checked all the setting and rebooted the base, turn the cameras on and off. I even increased the sensitivity of the motion setting.
I will continue to work with them and see what I can figure out.
Bob
Also noticed that the Speaker volume is set to zero and will not maintain the new settings.
Bob
Bob
As of 2:15 EST the cameras started sensing motion and recording, still the audio speaker volume default to zero on that page.
