how do i shut off the cam? im setting up 2 new ones and dont need to waste battery power until i find the sopts i want thanks im guessin removing the battery but should be an easier way
Older Vuezones had a switch... not Arlo.
But, you got it right, just remove the batteries.
If it's for a short while and they are sync'ed to the base then I'd just leave them alone... they go into a sleep mode when not in use and consume very little battery power.
THANKS I THOUGHT THAT BUT NOW IM SURE
