  • 2 Replies
  • 3325 Views
dddbo
Camera is detecting motion sending alerts but there is nothing in the way.  Is there a solution.?
nngnng
Yes- The solution is to return the product MAJOR DEFECT.........................................
Yes....
Possibility of some reflection of IR setting off the camera.... Lower the angle of view to try and eliminate it.
There is also a sensitivity adjust in the Mode for the cameras
