setting distance
Camera is detecting motion sending alerts but there is nothing in the way. Is there a solution.?
Yes- The solution is to return the product MAJOR DEFECT.........................................
dddbo wrote:Camera is detecting motion sending alerts but there is nothing in the way. Is there a solution.?
Yes....
Possibility of some reflection of IR setting off the camera.... Lower the angle of view to try and eliminate it.
There is also a sensitivity adjust in the Mode for the cameras
