router
  • 2 Replies
  • 13572 Views
gtcoats
My Verizon router has the code T5FH9; is this compatible?
Don't know what the code is or where you got it (model number?) but any router that has an available Ethernet port should be fine.
JohnR
Hello gtcoats,
I am not familiar with this code for a router, would you be able to share the model number? Any router with a DHCP server function and LAN should be compatible with the Arlo unit.
You can check the minimum requirements here.
Thanks,
JohnR
Arlo Team
Thanks,
JohnR
Netgear Community Team
