minimum Internet speed/velocity
if i only use for live view of camers on my phone and do not bother about recording on cloud, i am using netger router with it speed of 600 mb/sec. so the router is enought to transfer content to my phone. do i still have issue because my internet upload is only 0.5 mb/sec.
also if i want to use it in india with 240 v , if i change the adaptor of base with same configuration will it work ?or i may use 110 to 240 convertor.
Arlo is stated as a minimum of 1mb transfer rate.... It doesn't matter if your live viewing or recording and it has the same trip. ( camera>base>internet>server then back the same way to the phone )
As to if it would work with the slower speed, I don't know. I have seen stated that video level may degrade with a lower transfer rate than the minimum.
As to the 120-240v... the base runs on 12v DC at 1.5a via a coaxial plug... so it shouldn't be to hard to find a 240v to DC adapter (or a 240 to 120 adapter)
