rechargeable battery usage
we all know that the Netgear up to 6 months for batteries is for very light usage.
On 3 of my cams I use rechargeables, use considerably more and set record to 120 sec. I also manually view briefly manually every couple hours.
These two use the recomended Tenergys:
average 16 recordings a day with battery level dropping an average of 2.5% per day
average 24 recordings a day with battery level dropping an average of 5.2% per day
A Chinese bought set in a third camera
averaged 16 recordings a day and battery level dropped an average of 6.3% per day.
Notice the first 10-15% drop relatively quickly and then slows.
And what are you seeing in number of DAYS with your usage?
In my runs i get 40 - 60 days (depending on how much recordings ) using approved or identical type cells
getting 20-40 days before recharging, but then recording 32 to 48 min per day which is probably more than most would.
