How can the base be re-booted remotely? Is that what the "restart" button is in the app? If not, what does the "restart" button do?
Yup, you got it. "Restart" = reboot.
tfunkster200 wrote:
I have an Android, (..) where do I find the "restart" button on my app???
Settings -> My Devices -> [Your Base Station Name] -> Restart Button.
Note that [Your Base Station Name] stands for the name of your base station, which - by default - is its serial number or whatever other name you gave it.
Also, try a browser. You can do this even on the phone if you tell the browser to request the desktop version. Chrome does this by using the browser menu (3 vertical dots, top right).
tfunkster200 wrote:
I have very limited function with this system it seems on my app, most is all in gray.
You mean the videos are in gray? That's night vision. During the day they should be in color.
tfunkster200 wrote:
My videos do not store on "the cloud" If the base station is off, I can't access my library.
You should never turn off the base station, otherwise your system cannot be armed. In fact, you will drain the cameras' batteries quicker that way, because they are using more power to try to connect to the base station. So, they are in constant search mode which wastes battery power. Leave the base station on 24/7.
tfunkster200 wrote:
My library does not record after 7 days unless I go and delete at least a full days worth of clips and that is one by one! Then having to reboot every few days so my cameras stay online or to get them to record! Could I be dealing with a software issue?? Thoughts???
How many clips do you have per day? Rougly what is your total recording time of video clips per day? If you use the web interface, you can select all videos of one day and delete them in one operation. I'm not sure what's going that you can't record after 7 days. That should not happen. You should never run out of space.
