"format unrecognized" error
When I download a video file its in a format unrecognized by my players. I have a Win 8.1 machine, with Win Media Play and VLC Media Player installed. Both have always worked for mp3/4 files, but not with the files downloaded from Arlo. The error I get is something like "unrecognized format". This only happens with videos downloaded from Arlo. Does anyone know how to fix this?
Are the file extenions noted as .MP4? If you right-click on the file and choose Properties and then the Details tab, does it show with a certain resolution and frame rate? If not, the download sounds goobered. If it does, try uninstalling VLC and reinstall. I have a fresh, basic load of VLC on Win10 that works with no problem.
Tested on my Windows 8.1 with WMP.. no VLC installed.. It plays fine.. Try Updating.. You might have configuration or missing/corrupted codec-plugin issue.. Uninstall/Re-install/Update might fix it or download the specific missing/corrupted file .dll for WMP...
Thank folks. Videos of other sources play correctly for me, and its unlikely both players have a corrupted codec. 'any idea what the two players (WMP and VLC) might share in common? The most likely problem is some corrupted common resource. Thoughts?
paulg wrote:Thank folks. Videos of other sources play correctly for me, and its unlikely both players have a corrupted codec. 'any idea what the two players (WMP and VLC) might share in common? The most likely problem is some corrupted common resource. Thoughts?
Yes, unlikely both players have a corrupted codec.. But all of a suddent both did not work.. so definitely there's a bug somewhere in your computer that made that happen.. It needs attention and fix.. else, it's gonna' get worse later on..
