When I use the app it states "Your Arlo app requires an update to continue" then takes me to the App Store where all I can do is "Open" not update so it takes me right back to "Your Arlo app requires an update to continue". How do I get our of this vicous cycle?
If you are having trouble getting the update, uninstall your Arlo mobile app and download a fresh version from the app store. Are you still seeing the same behavior?
Delete the app and then go to the store and install.
Yeah, me too. Just started today. Very annoying. What's going on with the app that it's calling for a non-existent update?
I had this today - when you get taken to the app store (and see the "open" button) just click on the "updates" button in the bottom right. You'll see a list of all the apps with an update available, and Arlo will be in the list. No need to delete anything 🙂
Thank you community for your help. Deleting the app then reloading worked -- although I seemed to have lost my favorites but at least it's working again. Appreciate your help.
