Is anyone else seeing this in iOS apps' wifi cameras today and late last night? I saw this in before and after upgrading yesterday's app. I don't see this in https://my.arlo.com as well.
Thank you for reading and hopefully answering soon. 🙂
Best answers
Our development team is still looking into this issue. We'll be sure to provide any new information or update when we hear back from them. We appreciate everyone's patience regarding this issue.
The development team is investigating this issue. We will provide an update as soon as we have more information to share with the community.
6 months later and 'The development team is investigating this issue.' ? Still?
Ditto. 😞
I believe I found what is causing the issue but it seems to be a firmware length issue. If you open the iOS app the and click on the setting symbol of camera 1, Click device info. You are now seeing the firmware, hardware and serial number. Next minimize the app and then re-activate (return to home and the swipe up to reopen the app on iphone XS). You will see the firmware filename expand out and then shrink back in like the filename is 3 digits too long to have to update everytime we open the app. I figure I would try to support given it taking so long. Maybe you could push out another firmware update with a slightly shorter filename.
I actually don't see how this is related.
My reply was meant for the development team. It doesn't do us as users any good given the issue is on iOS devices (must be app related like previous replies imply) and they must need a little support. I believe maybe two weeks was a good time limit to address this issue as it can't be a very big issue to fix. I say that because it all started when we updated our cameras to the new firmware.
I posted what worked for me on stopping these annoying messages earlier. But I'm unsure that worked for other people that tried it - YMMV. Maybe still worth a shot b/c I've been good since then and they have not returned - knocking on wood. I'm 100% sure it was introduced by the firmware updating but it is also tied to the app... probably a corner case that's darn hard to reproduce.
Stay safe, stay alive. Peace.
Is it me or does gattaca's link doesn't click? 😞
I’m not sure if this is an iOS issue. I don’t have this problem on my ipad6. It’s only on my iphone11.
Sorry. IDK... referring to links in this forum board behaves oddly. I'll try again below. If not just goto page 1 of this thread and see message # 24.
IDK if this will work for everyone. I'm reporting what worked for my cams/setup/iPhone after that FW update and those messages. These messages no longer appear on my iPhone when checking the cams and everything appears normal. It's not the first time I've had trouble after Arlo's firmware updates. I had to do a similar procedure a few years ago to recover then too. That time I think all of the cams motion sensors stopped recording vids.
Yeah it was a big PITA.... but that process fixed it then too.
I agree, Arlo Engineering needs to fix this PRONTO. It appeared after that FW update. Good luck - YMMV. Stay safe, stay alive. Peace.
At last it seems was fixed in yesterday’s new iOS app’s version!
This issue should now be fixed on the the latest version of the Arlo iOS app, which is 3.5.12. Please make sure to update to the latest version through the iOS App Store.
If you're still experiencing this issue, please let us know.
EDIT/UPDATE (Jan 11 2022): Some users are mentioning that they're not seeing version 3.5.12 on their iOS device. You may need to update your Arlo iOS app manually, which you can refer to here: How to manually update apps on your Apple device
I’ve attached a screenshot of my current installed apps awaiting updates on my iPad Pro. You can see that 3.5.12 is awaiting an upgrade. Try clicking on your profile (or husbands) from the Apple Store (upper right of screen). Once that opens, hold your finger on the screen and slide down which will refresh your apps. You should see the update then. Same process from your iPhone. Now, there might be an issue because you're a "Family Member" (e.g. Guest) on your Husband’s account.
Got it! It needed the refresh to find the awaiting updates. Thanks. Now fingers crossed the update corrects the issue.
It has nothing to do with who is "Primary" on the Arlo app or not. This is an Apple app store update issue. What version of iOS are you running? Model of iPhone? Do you have app updates turned off?
@George-F wrote:
My husband just checked his Arlo app, because his is primary, and there is no update for 3.5.12 nor is there one on mine!!!
If you are running iOS you can open the app store, and search the app (as if you were doing a new install). You should then see an option to update it.
Otherwise, wait until the iPhone gets to it on its own.
@George-F Try uninstalling the App then download it again from the store and the latest will install. I needed to do this a few times in the past when it didn't show up in updates.
