one of my Arlo cameras is OFFLINE.
  • 1 Reply
  • 2440 Views
CMMJA
 I have 2 wireless ARLO outside cameras linked to my iPad and iPhone.
I looked at the Arlo app and it says one of my cameras is OFFLINE.
I did not set up my system and I am technically "challenged".
Is there any easy way to get that one camera back online?
It may just be offline due to lack of battery power...
First thing you can try that's simple is to reboot the BASE ( by power button, off then on.. takes about a min or two to come back online ) or
From your SETTINGS pick the Arlo base device and use the RESTART button ( does the same thing )
After this if nothing works, it would prob require you to physically get the camera and reset or resync it ( or battery change )
Ask and help will come  🙂
