One of three cameras not working
One of three cameras not working, worked during initial set up and for a few days after, nothing since, reset not working, changed batteries with working camera, nothing. Help?
WHile it could be a bad camera, how did you reset? You should only be using the reset button until the LEDs flash amber. Remove all devices in Settings, My Devices. Use the Add Device button on the Devices tab and add the base followed by syncing the cameras, making sure the batteries are good. Are the LEDs on the base green (power, Internet and camera)? Can you now use the 3rd camera?
