  • 2573 Views
carlsey54
on of my camera is showing blurr colors in the back ground how do i get that out
It could be caused by a poor signal strength. Try swapping another camera that's fine and see if the problem is the camera or location.
Joeduvarney22
One camera as blurry colors in background...other 3 cameras work fine...the one that doesn't is within range... What can I do to correct the problem?
Did you try swapping camera positions as suggested above?
