When I try to sync the 3rd camera the amber light blinks non stop. I have tried syncing it 10 times and even took out the batteries for 30 minutes, Still can't sync it. Any help would be appreciated. Thanks!
Could be bad batteries or a bad camera. A constant flashing amber LED implies low battery - use a different set of batteries (use the set from another camera if you don't happen to have another set of fresh batteries and put the suspect set into your working camera). If things work, it's the batteries.
Otherwise, I'd either return the camera for replacement at the store you purchased from or would open a trouble ticket for possible RMA.
Power cycle the base station and be sure to press the sync button for only a brief time (1-2 seconds).
