The new app update for iOS doubled the devices the. Wiped out my base station and set up. Fix it
This issue has been resolved in iOS app version 2.3.2 please visit the app store and update your Arlo mobile app to this latest version.
They are aware of the problem and working on it.
This is compromising the security of my house and the app needs to be repaired ASAP.
Please download the latest version of the iOS Arlo mobile app (2.3.1) from the app store.
Are you still seeing this behavior?
All cameras are still missing and cannot Add Base Station either. This update occurred on 12/21. It duplicated the cameras then wiped them out, and finally the Base Station would not respond.
I removed the Base station and started a full New Setup but the Base will not respond.
The system was working great until that update went in and I am very unhappy as our home security is now compromised and with Xmas deliveries being laid on the doorstep we are worried nefarious individuals will target our house and steal packages off the porch.
This is is not good at all. Very very unhappy.
If resetting the base to start over fresh, DO NOT use the New System Setup. Log in and use the Add Device button on the Devices tab after removing everything from Settings, My Devices.
Factory reset Base Station with cat5 unplugged. Plugged cat5 back in hit reset. App had been switched to another band on my Netgear dual band DSL router when update was loaded on 12/21. Resynching all cameras. Coming back to life. Something about that update and Dual band routers.
The Arlo update on ios - the seeing double faux pas extends to the Arlo Q as well. Re installing the app and re syncing the cameras does not work [for me anyway] so waiting for a fix from Netgear seems to be the best option at the moment.
Arlo development team - I'm sure this issue bites into time with your families this Christmas. Thank you for your hard work and all the best to the team.
If camera does not appear try this
Power down your hub for 7 seconds. When the left two lights turn green, means your hub is connected to the internet, press the sync button and then the button on your camera.
If you see two of the same camera images wait for the app fix that is underway.
Same issue. App shows double feeds from my two cameras. Removed both cameras and then resynced. On the webpage, there is only one feed from each camera, but on both iPad and iPhone (both with the 2.3.1 update), I see double feeds. Odd thing is the double feed from each camera shows the battery life as zero, but the "original" feed from both cameras shows the battery life as 80% plus (I've changed the batteries in both cameras within the past two weeks).
OK
iOS app is back to normal without an app update. Makes me think the issue was at the server level? Anyway, no more double viewing through the iOS app.
