The new app update for iOS doubled the devices the. Wiped out my base station and set up. Fix it
I found out about (not) deleting the duplicate feeds. It means you lose all your settings and start from scratch.
The way I can tell the good from the ghost is that the 4 ghosts never seem to connect and display an image.
FYI: I have a kit that came with 1 base and 4 (in use) Pro cameras.
Having the same issue. Just started tonight. have resynced and rebooted everything twice over, nothing resolved the issue. Any updated Netgear on the status of this issue for iOS users?
My system has worked correctly for 3 days now. I have an iPhone 6s and my wife has iPhone 7. I re-synced the cameras one time and reinstalled the app several times, especially on my wife's phone. It seems like the problem is resolving for some people like in my case, and not for others.
Should we wait while you find a safe space?
LOL
Too late for me. After encountering the double vision problem I deleted one of the base stations. Now both base stations are gone. I now have a 4 hour drive to re-add the device. Everything worked fine for me until today.
This issue is still being investigated by the engineering team. Please do not attempt to remove the duplicate cameras as this does not resolve the issue. Some users have reported having success by uninstalling the Arlo mobile app and downloading a fresh version from the app store. I will post an update when I have more information.
We apologize for any inconvenience this may cause and thank you for your patience,
Include me in the column of owners who tried reinstalling the app without resolving the problem.
I'm having the same problem with each camera being duplicated when using the iPhone App. One camera has normal battery stats and the other shows a dead battery. I tried the 100% unload all devices and reload, and the duplicates came back. If I delete any of the cameras that show the dead battery, it deletes both of the camera views for that single camera. It also shows I have two base stations but one is searching for the connection.
What's interesting is this problem only exists on my iPhone 6Plus running the latest iOS 10. Everything is fine on my desktop computer through Internet Explorer and all is OK using my iPad Arlo App. This all ocurred after the update to fix the dark camera views.
