Can you have both Arlo and Arlo Pro on the same base?
  • 2 Replies
  • 4894 Views
KevinPHalloran
Changing batteries in my outdoor Arlo's is bothersome and expensive.
Thinking of adding a couple Arlo Pro's to the outside and bringing the standard Arlo's indoors.
Can I have both Arlo and Arlo Pro on the same base? What about the mobile application for
viewing, etc?
But about batteries again - any reliable suggestions for rechargable batteries for the Arlo units?
CR123's are expensive and hard to find.
Thanks to all in advance!
Kevin
yes you can mix any combo  of the Arlo and Arlo Pro to either base.
The OEM battereis run about $1.40 online ( in 12 pack ) wihich is a good price.  http://www.batteryjunction.com/energizer-cr123a.html
Netgear has a set of rechargeables and charger approved by them coming out soon, see
https://www.amazon.com/dp/B01N0DVFA7
Arlo Pro cameras are battery tolerated, too. You can run them off wall power but your warranty is at risk doing this outdoors.
