my battery usage
I know people keep wondering how the batteries should hold out so, now that my usage has settled down I thought I'd share my usage, and maybe others could add theirs to give people wondering an idea. All 4 of my cameras are outside with temps often going down to -10 to -15 Celcius at night. One cam averages less than 1 vid capture a day so wont be included. My recording length is set for 120 sec and each cam gets checked with brief live view about 5x a day.
CAM 2 - has Tenergy Gold colored recharegeables: Average 15 captures a day/night and drops battery level an average of 2% per day night CAM 3- has Tenergy Gold colored recharegeables: Average 19 captures a day/night and drops battery level an average of 3% per day/night CAM 4 has original non-rechargeable Panasonics Average 23 captures a day/night and drops battery level an average of 5.5% per day/night Hopefully this is useful.
P.S. I'd posted this erroneously as Arlo Go and couldn't find way of editing so reposting
Usage as you know is the important factor as to battery life.... There are many charts/graphs, etc done on batteries if you go and review the older rechargeable threads....
Cliff notes are OEM can run a good time in spec or with less than spec usage, rechargeables over time are better in heavy use but still run a max of about 60 days ( due only to capacity being less than 1/2 of OEM )
Here's a track of 4 li-ion cells, 500mahr capacity over time... (test ended when one cell dropped below set V and drop out was to be next day)
Spec use 4 mins per (** bump up was due to non usage and cells recouped a bit )
if you want to do the math for %, be my guest ![]()
Later tests were more stable at end run as I started matching cells in the set of 4.
BTW, drop out occurs at about 2.75-2.8v
It's snowing here... a good day to read one of the threads, 30 pages and charts contained in early test... rememeber at start, battery gauge was not optimized to the 3.7v li-ion cells till late 2015 (IIRR)
https://community.netgear.com/t5/Arlo/Rechargeable
