lower control panel
Retired_Member
Not applicable
2018-07-20
10:19 AM
When I open the desktop app on my pc to view the cameras, is there a way to have the lower control panel fade out of the way while viewing and come back when you hover over that area?
alan854,
It sounds like you're referring to the interface icons on the camera widget (pause, record, brightness etc.) when live streaming. There is no way to minimize or hide this panel.
Retired_Member
Not applicable
2018-07-29
11:53 AM
thanks for the reply. there is a box that says hit "esc" to exit full screen, then it fades away. Arlo should implement that on the lower panel.
