looking for camera to inspect bird nests
  • 1 Reply
  • 1691 Views
adampeck
Hi,
I do research on Black-Cockatoos, birds which nest in tree hollows. We have a telescopic pole with a wireless camera attached to look inside and check for eggs, chicks, etc. We have a very poor quality camera currently (a wireless 'pipe inspection' camera https://www.ebay.com/itm/143335387143?ViewItem=&item=143335387143), the resolution and focus are just not good enough. Is there an Arlo product which could fit this bill? Needs to be lightweight, have good LED lights and focus between 30cm and 3m. Or any other recommendations for other brands suitable.
Thanks in advance, Adam
The only camera that works without direct internet access is the GO camera, but that is BIG compared to the lipstick camera you have. All the others need wifi or a base station ( Go works on cellular )
You may be better served looking into a sort of 'spy' cameras ...
