live viewing vs recording
am i right in concluding that the battery drain would be the same if i'm doing lengthy live viewing as opposed to recording the same. I figure that since i think the cam involvement is the same either way? Or am I missing something?
I think they're about the same, yes
power usage; highest to lowest
(Peak power drain seen with IR on about 200ma at start up)
Record/Live with IR on
Record/Live
Motion detect on
Disarmed/Sleep ( almost none )
