  • 5 Replies
  • 8165 Views
  • 5 In Conversation
cerhorn
H11 hardware, firmware 1.2.16720
After a year or so of reliable operation, a couple of cameras are failing to detect motion intermittently.  I can stand right in front of them, wave arms, walk back and forth, come into view, go out of view, and nothing is recorded.  Then I do a motion detection test on the cameras in question, and the LED lights up immediately when I come into view.  After the motion detection test, they function correctly, record motion and store video.  Motion detection test seems to reset them.  Why?
5 REPLIES 5
veener79
Luminary
Luminary
It seems a bit of us are having this issue after that firmware update for the base.  😞
cerhorn,
How often are you experiencing this behavior? You might try a base station reboot and test again to see if the issue still occurs.
cerhorn
I did power cycle the base, and motion seems to be working.  Continuing to test......
mcgreen1966
Hi i am having exactly the same issue, both my cameras have become totally intermittant.
its only recently, although i dont remember updating any firmware. only the App.
if i Disarm, then Re-Arm the cameras they start working again .
hope this gets resolved soon.
i have had over 14 months of trouble free use.
many thanks
Mark
Sometimes the quickest resolution is to remove all devices from Settings, My Devices and start fresh. PITA but if it works...
