install and monitor a second location
  • 1 Reply
  • 3094 Views
TomMarshall
I want to install a system at a second location. Do I need two seperate id's and log ins?
No... Even on the Basic ( free ) level, there is no limit of bases... just the # of cameras.
So if you have 2 bases you can use them on the same account with a total of 5 cameras and they don't have to be in the same location.
Keep in mind, I've found it easier to set up at your home location and then move the base and associated cameras to the new, usu a just plug in and it should work. ( tho not necessary, you can just set up in the new location with you login/pw )
Also remember that EACH base will on the same account but will have to be armed/scheduled separately.
