  • 9 Replies
  • 5543 Views
bayonnedoom
my batteies are at 22% after 1 day use did i get a bad batch of batteries?
9 REPLIES 9
How did you use them? How many minutes total of live view, positioning, recording, etc.? What's the WiFi signal showing?
bayonnedoom
the wifi at full strenght i used for a few minutes to set up after an hour or so the batteries wre dow 10% today down too 22 ,44,49,79 no much use
steve_t
Master Master
What batteries does the Arlo Go use? Is that the model you're talking about?
bayonnedoom
arlo smart home indoor/outdoor wireless high definition security camera 4 pack
bayonnedoom
tenergy propel cr123 lithium
steve_t
Master Master
Oh right. Just check which section you're posting in for the next time you post.
Not sure about your current batteries but I highly recommend you consider the Tenergy rechargeable batteries. You'll save a ton in the long run
The Tenergy propel cr123 lithium batteries are your problem - they're only 3v.  You need the lithium-ion batteries of 3.7v.  Arlo has certified a set of those for use in the original wireless cameras - check the product accessories here or https://www.amazon.com/Combo-Batteries-Wire-Free-Security-Certified/dp/B01N0DVFA7/ref=sr_1_4?s=elect...
Jeff... those are primary cells, non rechargeable and just like the OEM cells,.... they should work fine. ( not 3v rechargeables )
(The Tenergy Propel CR123A 3V non-rechargeable lithium battery is one of the most popular CR123A lithium batteries on the market.)
As to why they don't last long, it could be bad cells, weak signal, bad camera.... Are the cameras  all doing the same thing ?
Oops. I'da sworn they were rechargeables.
