What does the icon to the right of the man running represent? It looks like sound waves. One on mine has 2 red lines instead of all green like the other cameras.
I believe that is the strength of your internet connection.
Thank you. It is the furthest from the computer. I appreciate the help.
Garry
Actually, it's the signal strength between the camera and base station for the dedicated WiFi connection between those two. Doesn't directly relate to the Internet connection.
That's actually what I meant. I just worded it wrong. Thanks for clarifying. What it means is that if I walk down the street with a camera I'm going to lose lines showing up as I go along.
