Hi @Snowsucks,
What iPhone are you using? Have you tried checking your notifications on your iPhone settings and try to toggle the notifications off and on?
iPhone 7 plus. Yes, I've uninstalled and re installed the app. I've switched the notivications on and off in settings as well.
We use to get an alert if there was motion. Now we don't get any notifications, the app still records, however it doesn't alert us at all on the phone.
What subscription do you have if any?
If on a smart plan have you setup your notifications for each camera on the smart notifications page under settings?
Have you gone to your IOS settings and scrolled all the way to the Arlo app at the bottom and confirmed notifications are on?
no subscription, but grandfathered in under having had it before they changed anything.
Yes, set up notifications under each camera.
Yes, scrolled and confirmed
thank you fixed the problem notification was turned off
Hi @Snowsucks,
Have you tried checking your modes/rules to make sure that the push notifications are enabled on the Arlo iOS app? Try to disable the push notifications and save. And then try to re-enable the push notifications and save.
