Hello
I am having an issue administering Arlo camera from iOS.
I have used Arlo from a web browser (Safari on Mac) without issue.
However the Arlo App on iPhone and iPad (iOS 11) started having issues. I can no longer change record times (the slider is greyed out) on some cameras but can on others. If I change the record time via web browser the new record time is not reflected iOS app.
i have deleted/re-added Apps without success
So using a web browser - All is A-OK
Using iOS app - some settings can no longer be changed and/or may not report current values correctly.
This seem to have begun after there was a server outage at NetGear two days ago. Maybe that is just a coincidence.
Anyone know what is causing this?
thanks
Al
Well I was able to get this to work. Not sure if this is a bug, feature, pilot error or whatever.
Turns out the the camera I could not change recording length from iOS was a "new" camera that with default settings (10s for recording). Once I changed the recording length via a web browser the iOS slider bar for recording magically ustuck itself.
Maybe this is a one-off or a persistant issue but at least it now works.
alcat,
Consider rebooting your base station (using the on-off button), allow the base station to come back online and try again. Do you still see the same behavior?
Thanks .. if the problem returns I will try rebooting the base.
It seems changing the default recording time via the browser somehow unstuck the slider bar in the App.
Maybe a coincidence? Maybe not? But at least this is working again.
thanks again
