  • 4766 Views
silvia_fino
I've read all documentation on community and try a lot of times.
I can control base by remote and than my Internet connection is ok but camera don't sync with base.
I pushed the sync button on the base two seconds until the green light blinks, than I pushed the sync on the camera but blu light blink slowly. The distance between base and camera is around 40 cm.
What I've to do?
Thanks in advance,
Silvia
The 2 second press is likely the problem. If you press too long it causes problems. I press briefly (<1 second) and it works fine.
silvia_fino
Thank you for your interest. I've tried as you suggest but it doesn't work  😞
Turn the base off and back on. Reinsert the battery in the camera to reset it. Try the sync again.
