Can someone tell me how to reboot my base station so it will update the FW. I have auto update on but it has not updated yet.
Good afternoon WaltPolston,
I have attempted to replicate the issue you described on another post. Let's see if we can't walk through this together. Please see instructions below for updating firmware when prompted after login:
- Upon login if a firmware update is available you will see the following prompt:
- NOTE: Before updating firmware temporarily change the mode to “All motion off” and do not stream the cameras during this process.
- To update click UPDATE
- You will be redirected to the Base Station Settings page
- Click UPDATE
- You will be prompted to confirm the action
- Click/tap Update
- The firmware will begin downloading to the base station
- Click/tap OK
- Once the firmware has been downloaded and applied the base station will reboot itself
- Observe the base station for the Amber power LED
- Once the power, internet and camera LEDs return to a solid state the firmware update has completed.
Please let me know if this still does not resolve the issue with updating the firmware for your Arlo system.
You may also want to check out the following article that provides information on the minimum requirements to install and use the Arlo System.
What are the minimum requirements for installing my Arlo system?
I look forward to your next update.
Best Regards,
Christine
____
Please click
KUDOS or REPLY if you found this helpful.
This did not work. I am not sure what to do next. My upload speed is 0.14 and I think someone said it needs to be around 1.0. Not sure where I can get this kind of upload speed. My feeling is that it should be told upfront that if you do not have this do not buy it.
As far as the upload speed requirement, it is posted on the website: https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-the-minimum-requirements-for-installin...
