Battery life/motion detection
  • 1 Reply
  • 8367 Views
adammolinaro
Arlo,
I have replaced my batteries on 3/21/15 and the camera is already showing half the bars indicating that my batteries will need replaced far earlier than the typical 4-6months.
I have the camera set on battery quality mode to try and get the most life out of the batteries. The camera goes off several times from around 1pm - 4pm due to the temperature changes and the sun position I assume. I have motion sensitivity set to only 60% (any lower and I don't catch images of those coming to my front door) and I have the camera facing as far down as possible (any lower and I will be looking at people's feet as opposed to thier face).
Is there anything else I should be doing to maximize my battery life and/or minimize the motion detection of the sun?
It sounds like the sun moving across the sky at that time of day is causing a large amount of IR that is giving false triggers.
If changing the sensitivity lower doesn't work, you may have to chnge the location of the camera so light ( or reflection of same ) doesn't hit the camera during that time.
