I can't figure out how to change the notification to stop emails. Can you help
Sant,
Click mode and select your device id and you should see all of your modes. Click the pencil icon for the mode you want to edit and you will then see a list of rules for that mode. Click the rule you want to edit and you will then see all options available for that rule. To turn off e-mail alerts uncheck "Send email alert" and click Save.
For more information on the changes take a look at this article: How do I create and define Modes & Rules?
Sant,
Worked for me too, Thanks.
