I have 2 cameras that I want to reconnect to my system but I do not know what type of cameras they are. As far as I can tell neither can be opened. the hole to attach them is centered on the back.
@dennis51 wrote:
don't know when I got them but at least 10 months ago. Yes the cover for recharging and a button is on the bottom. There is a number at the top of the flap - VMC2030
These are the first generation Essential Outdoor cameras.
FWIW, the warranty is 12 months, so potentially already expired.
Do you know when they were purchased?
Does it have a flap over the charging port on the bottom? If it does, then look for a faint label at the top where the flap opens. You might have to angle the camera a bit to get a reflection so you can read it.
Thank you!!
Appreciate your assistance!
