Hello,
My base station ethernet port lost it's lining so I am not able to insert the ethernet cable snuggly. Any suggestions?
Thanks,
Wil
Buy a new base
Unfortunately, that's the likely scenario. If you're clever and want to trysome things, perhaps wrapping some tape around the cable connector could help or find someone that may be able to take the case off and replace the connector.
