i had logged into my account and registered the product. when i tried to login to create camera settings, i get a message email not found ?? how can it be ??
Hi samrajd,
I have checked your email address samrajd@hotmail.com and found that there is no Arlo device registered to it. You must have registered that email only for this forum.
Please go to https://arlo.netgear.com/#/login then click NEW SYSTEM SETUP button. Make sure the cmputer/smart phone/tablet you are using the connected to the same LAN where the Arlo system is. See How do I set up and sync my Arlo cameras? for sync setup of cameras with the base station.
Hope this helps and I look forward to your update.
Regards,
NETGEAR Community Team
Hi samrajd,
Regards,
I moved and canceled my COMCAST service so my old email [email protected] no longer works.
I need to change my email to [email protected] and reset my password to get to my Arlo account.
Thank you
John Gotthold
Hello jgotthold,
You may change the email address by getting to Settings - Personal Information.
Just change the current email address under Personal Information, you will also have to enter the password that you use to login to Arlo then click SAVE. This will not log you out. To test, logout then log back in using the new email address and the password that you use to login to Arlo.
Regards,
THANK YOU. I SET RIGHT THE ISSUE ON THE SAME DAY BY LOGGING OUT AND THEN LOGGING IN AFTER 15 MINUTES OR SO
